Kyal and WFL Invite you to a World Premiere at EMO
Added to MTDCNC by Kyal Machine Tools Limted on 15 August 2015
In Milan, the Linz-based company WFL Millturn Technologies GmbH & Co. KG is showing its novel innovations relating to high-end Technologies. WFL is displaying an M80 MILLTURN / 4500mm as well as a smaller machine model M50 MILLTURN / 3000mm at EMO Milan on a stand over 350m² in size. A broad spectrum of new technologies round out the portfolio: amongst others internal machining technologies, gear cutting solutions, additive manufacturing with an integrated laser unit, laser hardening and many more innovations will be demonstrated on site.
Integrated Laser Unit I The unbeatable performance in machining continues in the area of additive manufacturing being presented on the M80 MILLTURN. With the integration of a 6KW high performance laser it is not only possible to achieve industrial utilizable material melting, but also precise and low distortion hardening of tribological threatened surfaces. When using the technology cladding, it is possible to achieve with high build-up rates not only linear ways, but through the use of the many NC-axis of a MILLTURN you can create nearly any geometric form. Therefore complex cooling channels or curved connecting flanges can be efficiently manufactured.
Gear machining at a glance I An important field of expertise are the different gear cutting techniques. The M50 MILLTURN is showing various gear cutting techniques, which enable the customer to use the MILLTURNs even more efficiently.
See for yourself our latest innovations and visit us in hall 3 – booth no. E14.
