The new 3D Systems ProX DMP320 Printer is Now Available from HK3D
Added to MTDCNC by HK 3D Solutions Ltd on 23 March 2016
Now available from HK3D is the new ProX DMP 320 3D metal printing machine. Developed with high precision and high throughput at the heart of its design, the ProX DMP 320 offers fast build turnaround times in demanding 24/7 production environments.
The latest DMP (Direct Metal Printing) machine from HK3D has been designed for the production environment with low operating costs to exceed the expectations of industry. This production ready system has been designed for productivity with quick-swap build modules and fast powder recycling.
Strong mechanical properties are guaranteed with the lowest O2 during builds (25ppm). This gives the end user exceptionally strong parts of high chemical purity with the added benefit of low operating costs that are derived from efficient consumables management and shared ancillary equipment that lower the total cost of ownership.
From a material perspective, the new ProX DMP 320 can print with LaserForm™ Ni718, LaserForm™ Stainless 316L, LaserForm™ Ti Gr. 1, LaserForm™ Ti Gr. 23 and also LaserForm™ Ti Gr. 5. These materials have been extensively tested with thousands of hours of parameter optimisation to ensure predictable and repeatable print quality.
The impressive new ProX DMP 320 provides complete design freedom as direct metal 3D printed parts can be stronger, lighter, longer lasting and higher performing than machined or cast assemblies. This latest technology enables the customer to manufacture superior performing products, faster and at a lower cost than with traditional fabrication methods.
With DMP customers can efficiently Streamline supply chains with complete control over the production process. Manufacturers no longer have to rely on specialty components from suppliers. Entire assemblies can be printed on-demand with fewer components.
This accelerates the time-to-market as R&D, prototyping and production can all be conducted on the same system. DMP users around the world are designing faster and compressing production times. Complex assemblies that take hundreds or even thousands of hours to machine and assemble can be transformed into a single high value part that is now printed in a matter of hours or days.
This can increase manufacturing agility as additive manufacturing requires no tooling, which reduces overheads and increases economies of scale. The end user can update designs and change the production mix to meet the ever changing market demands.
The ProX DMP 320 is easily scalable for high volume part production. A central server manages print jobs, materials, settings and maintenance for 24/7 productivity. Shared resources, including cooling and powder recycling systems can further increase efficiency. The ProX DMP 320 offers exchangeable manufacturing modules that support rapid material change or replenishment, in line with the printer configuration selected.
This impressive new machine is now available from HK3D Solutions, a company that is perfectly positioned to deliver and support this impressive next generation technology. In addition, the HK team has vast experience of the EDM market with its Mitsubishi range of machines and expert engineering division can demonstrate the complete process from print to final manufacture.
