Automation Updates Make Alphacam Even Faster
Added to MTDCNC by Vero Software on 18 May 2016
A number of new and enhanced items in the latest release of Alphacam software provide improvements with automation, machining and feature extraction. Alphacam 2016 R2 also contains a range of general improvements, along with new user interface commands for faster and simpler ways of working.
For example, Alphacam Clipboard enables entities to be cut, copied and pasted in the Drawing Area between different versions of the software open on the same PC. An additional option has been added for pre-drilled holes as the entry type on waveform roughing operations.
A new method has been added for extracting contours in work planes – by selecting faces to create the work plane for the extraction direction. “This improved feature extraction on user-selected multiple angled faces, is a real time-saver,” says EMEA Sales Manager Michael Pettit. “Feature Extraction has also been enhanced using an updated algorithm for finding contours.”
Some machining dialogs now have a new tab containing specific options for either 2D or 3D lead-in and lead-out paths, and there is also an option to save and open user-configured lead settings in addition to the defaults. “It’s now possible to copy all settings both ways between the lead-in and lead-out section.”
A new option achieves tool angle direction entry into a part when machining features such as grooves and slots. Selecting Sloping / Ramp Angle in the Lead-In/Out dialogs accesses this new function.  “When this checkbox is ticked it can be set to the same angle as the tool in the aggregate holder.” And there are changes to the separate, standalone, dialogs used for editing the leads of existing operations. Both the 2D and 3D versions of these dialogs – which are accessed by right clicking in the Project Manager – now have an apply button, for previewing leads before accepting changes.
“The Project Manager’s Insert page now contains commands for automatically inserting files in user-configured positions when they’re dragged into the Drawing Area. And additional dialogs create ‘new’ and ‘edit existing’ configurations can be selected from either the screen or user layers, specifying one or more snap points.
A new surface machining pattern has been added to the advanced 5-axis cycle. Flowline creates a toolpath aligned to either the U or V direction of the machining surface. “The user can determine the toolpath’s style, choosing the direction of the surface parameter lines. As only a single face is required, calculation is extremely fast.” A typical application for Flowline is where a specific surface texture, or grain, is required.
Still with 5-axis, the progress bar showing machining has been improved to give more feedback during complex toolpath calculations.
Automation Manager
A number of updates to Alphacam’s powerful Automation Manager include changes to Job Settings, Machining Order, Layer Mapping, and added support for nesting small parts into defined zones.
Job Settings: When adding new files to a job, Automation Manager sets parameters for Layer Mapping Setup, Material and Machining Order to ‘From Job’ by default. They can be overwritten if necessary, for a particular file.
Machining Order: The new Machining Order tab replaces the former Tool Ordering tab, defining the order of machining operations. The order lists are associated with layer mapping setups and machining styles...and multiple machining lists can be configured.
Layer Mapping: A New Drawing Layer command button has been added to the ribbon bar in the Layer Mapping Setup tab enabling users to create layers manually, and add layer names without having to import them from a drawing.
DXF/DWG Import Support For Z Levels From Parallel Planes: The Layer Mapping Setup tab has a new import option for DXF, DWG and Alphacam drawings and functions, meaning that parts which would have had work planes are simplified to Auto Z, and can be nested correctly.
Added Support For Nesting Small Parts Into Defined Zones: After drawing a sheet and adding it to the sheet database, parts can be defined as small parts for nesting zones by using the new Small Nested Part option in the Processing tab.
Among many changes to how Alphacam 2016 R2 handles geometry, new ribbon bar command buttons have been added to the Parametric Sketcher dialog, enabling users to associate an image with Parametric Sketches (.aeps) and Variables (.aepsvars). The associated images will be displayed in the Project Manager’s Insert page. Another benefit is that the dialog displayed when using the Run Parametric Sketch command is resizeable, and a toggle button switches between the associated image and preview.
Enhancements have been made to the Cut Spline/Polyline command for the machining of  sharp internal and external corners. A new option within the Panelling command function now automatically closes geometries in each panel by creating geometry elements along the panel edges.
Processing time is reduced when creating a simplified version of a detailed model where roughing paths do not require a high level of detail. Using the 3D / STL Utilities / Simplify command, the number of facets in a model can be reduced as a percentage of facets in the original. “This simplified STL model either replaces the original, or is created in addition to it.”
Headquartered in England, Vero Software designs, develops, and supplies CAD/CAM/CAE software radically enhancing the efficiency of design and manufacturing processes, providing its customers with exceptional value through high productivity gains and significantly reducing time to market. The company’s world-renowned brands include Alphacam, Cabinet Vision, Edgecam, Machining STRATEGIST, PEPS, Radan, SMIRT, SURFCAM, WorkNC and VISI, along with the production control MRP system Javelin. Despite the diversity of application, these solutions have one thing in common: they all address the rising challenges of achieving manufacturing efficiencies and bring huge value to the operations in which they are deployed.
Vero has direct offices in the UK, Germany, Italy, France, Japan, USA, Brazil, Netherlands, China, South Korea, Spain and India supplying products to more than 45 countries through its wholly owned subsidiaries and reseller network. Vero is part of Hexagon (Nordic exchange: HEXA B), a leading global provider of information technologies that drive quality and productivity across geospatial and industrial enterprise applications.
For more information, please visit www.verosoftware.com.
