CGTech to feature VERICUT Version 8
Added to MTDCNC by CGTech Ltd on 01 September 2016
Hove, England – CGTech will unveil the new VERICUT Version 8 at the 2016 International Machine Tool Show (IMTS) in Chicago, September 12-17 on Booth E-3346. VERICUT Version 8 will also be featured in the UK at 2016 events including the Advanced Engineering group of events at the NEC November 2-3.
VERICUT Machine simulation detects collisions and near-misses between all machine tool components such as axis slides, heads, turrets, rotary tables, spindles, tool changers, fixtures, workpieces, cutting tools, and other user-defined objects. Users can also set up ‘near-miss zones’ around components to check for close calls and detect over-travel errors. Machine movements and material replacement can even be simulated while stepping or playing backwards.
VERICUT CNC machine simulation, verification and optimisation software simulates all types of CNC machining, including drilling and trimming of composite parts, water jet, riveting, robots, mill/turn and parallel kinematics. The software operates independently, but can also be integrated with leading CAM systems including Dassault Systemes CATIA, Siemens PLM NX, Autodesk PowerMill and Vero EdgeCAM.
User Interface - New Ribbon Bar
VERICUT V8 features a new Ribbon Bar allowing the user to quickly select the required function.  As you move from tab to tab, the Ribbon bar dynamically updates to show the options available and options are grouped by the function they perform within VERICUT.
“VERICUT 8 is all about optimising our customers’ workflow to quickly access only the menu choices needed at the time,” said VERICUT Product Manager, Gene Cranata. “The Ribbon Bar helps users find the functionality they need quickly and with minimal mouse clicks.”
The Ribbon Bar is highly customisable, but to ease the transition for existing users, a “VERICUT Classic” setting organises all of the menus and options where users previously found them. Several other layout options are included and can be selected depending on the task at hand. Users can also create and save their own layouts as needed for different jobs.
Integration with cutting tool suppliers and tool management systems
The accuracy of the data input will directly affect the output. So, an accurate model of the cutting tool and holder is required for the effective and accurate simulation of the machining process. Leading cutting tool manufacturers, such as Sandvik, Kennametal and Iscar, now make 3D solid model data available and VERICUT can read in this model data for use in the simulation process. Many of the 3D models are available via the Machining Cloud App, and version 8 has been enhanced to take advantage of more Machining Cloud metadata. This can significantly simplify the configuration of tools for use in VERICUT. VERICUT also interfaces with tool management systems such as TDM Systems, Zoller, and WinTool for access to databases storing cutting tool information. Pre-setting suppliers including Zoller and Speroni can also interface to the software, so tool offsets and exact dimensions can be applied to the simulation process.
Consolidated reporting features
The VERICUT logger now displays messages and reports from many sources. In addition to errors, warnings, and other messages from the VERICUT session, it also displays information from AUTO-DIFF and X-Caliper. The messages can be grouped, sorted, and displayed in a variety of ways depending on user preference.
Graphical Tool Path Analysis
A new “Toolpath Trace” feature creates a wireframe of the motion path that can then be measured. No stock model needed to generate a path. Picking on a path in the wireframe automatically sets the simulation to the current line in the NC program.
Simulation of all types of machine tool brands
CGTech has worked with end users and machine tool manufacturers to create accurate and effective Virtual Machine Tool configurations. These range from simple 3-axis milling machines to multi-axis machining centres; simple 2-axis lathes to complex mill-turn centres with sub-spindles and robot loading; water jet and laser cutting, and machining/polishing robots.
VERICUT simulates every machine tool brand, including DMG MORI, MAZAK, Makino, Matsuura, Hermle, Chiron, Starrag, WFL, Okuma and many more.
