Delcam and CNC Robotics to show latest in machining with robots at MACH
Added to MTDCNC by AUTODESK on 28 February 2014
Delcam will combine with systems integrator CNC Robotics to show how easy it is to program complex robot machining operations with its PowerMILL Robot CAM system on stand 4011 at the MACH exhibition to be held at the NEC, Birmingham, from 7th to 11th April.  To see how easy it is to use PowerMILL Robot, please go to www.delcam.tv/cnc-polystyrene.
Robots can be extremely cost-effective for machining large parts, for the production of larger items of tooling, and for the trimming and drilling of panels in metal or composites.  Robots can also be programmed for part-to-tool applications, such as grinding or linishing.  The working area can be extended with linear tracks and rotary tables for even greater flexibility over the size and types of parts that can be manufactured.
PowerMILL Robot makes it as easy to program a robot for machining as it is to program a five-axis machine tool.  Furthermore, with PowerMILL Robot, users have access to the comprehensive range of multi-axis machining strategies within PowerMILL and can use all the system’s project management options to manage, store and retrieve data quickly and easily.
The core functionality of PowerMILL Robot consists of three main steps: programming, simulation (including analysis) and creation of the robot programs.
PowerMILL Robot can be used to simulate the complete machining operation and to control the robot’s movements through different variables, such as axis limits, axis priorities and workplane constraints.  Various aspects within the configuration of the robot cell, such as axis limits, tool constraints and home position, can be defined, and the simulation of the robot completed within those constraints.
The robot’s working envelope can be displayed to optimise the position of the part or initial stock, and so give maximum access to the material.  The maximum range of movements required of each axis can be viewed to analyse the robot’s behaviour and movements throughout the operation.
Any issues that may prevent the toolpaths from being completed successfully are highlighted, with notifications of the robot potentially reaching axis limits, singularities and collisions.  Graphs display the axis limits, wrist singularity and axis reversals, to give a better understanding of how the robot will move.  Similarly, the acceleration and deceleration of the robot’s axes are shown on time-based graphs.
Once the results of the simulation have been reviewed, and modified if necessary, the program can be output in the appropriate robot native language, for example for KUKA, ABB, Fanuc, Yaskawa Motoman or Stäubli equipment, eliminating any need for third-party translation software.  Acceleration, smoothing values and other robot-specific parameters can be defined as part of the output.  Full support for external axes, such as rotary tables and linear tracks, can be included, as well as dedicated tools for spindle calibration.
Overall, PowerMILL Robot helps users to maximise the machining capabilities of any robot in the shortest possible time.  The simplified workflow makes it easy to program, simulate, review and refine toolpaths, whilst PowerMILL Robot also enables the robot to machine to levels of accuracy similar to many CNC milling machines when cutting softer materials.
