Delcam Partmaker with Vortex roughing on show at MACH
Added to MTDCNC by AUTODESK on 17 March 2014
Delcam will demonstrate the 2014 version of its PartMaker CAM for the programming of turn-mill equipment, bar-fed mills and Swiss-type lathes on stand 4011 at the MACH exhibition to be held at the NEC, Birmingham, from 7th to 11th April.  This release sees the introduction of Delcam’s Vortex high-efficiency strategy for area clearance into the PartMaker CAM suite.  Other enhancements in the 2014 version include improved back-turning and 2D pocketing functionality, support for additional tool types and faster programming of lead-in and lead-out moves, and a new NC program viewer among other improvements.
Full details on the 2014 release, with videos demonstrating the new functionality, can be seen at www.delcam.tv/pmk2014/lz.
Vortex is Delcam’s unique high-speed roughing technology.  Vortex controls the maximum engagement angle of the cutter in the material, such that the angle calculated for the programmed stepover is never exceeded, even in internal corners.  This allows optimum cutting conditions to be maintained throughout the toolpath.
By controlling the maximum engagement angle and the load on the tool, Vortex can take deeper cuts than traditionally used in roughing operations.  Depths of cut up to the full flute length enable maximum material removal rate from solid carbide tooling and reduce machining times by up to 70%.  Vortex is available as a free upgrade to licensees of PartMaker’s Advanced Surface Machining (ASM) module that are on maintenance.
PartMaker 2014 includes improved functionality to support the automated programming of back-turning tools.  These tools are used across a wide variety of small-part turning applications, particularly in Swiss machining. With their unique geometry and cutting characteristics, back-turning tools can eliminate the need for multiple tools and so can reduce cycle times and improve surface finish.
However, given the multiple included angles and programmable radii found on these tools, they can present toolpath calculation challenges.  PartMaker 2014 overcomes these challenges with a unique, proprietary method for automating programming with back-turning tools on both the inside and outside diameter of turned parts.
Another area that has been improved is 2D pocketing.  This more powerful functionality allows for more efficient and intelligent material removal from 2D pockets.  The raster finishing strategy in PartMaker ASM has also been enhanced, resulting in less fragmented toolpaths without overlaps when machining highly complex shapes, thus improving part surface finish.  Removing overlaps also has the added benefit of reducing cycle time by preventing over-machining of parts and by minimising lifting of the tool.
PartMaker 2014 lets users enter lead-in and lead-out moves faster than ever before for both turning and milling operations.  The lead-in and lead-out dialogs have been combined into one form where values can automatically be copied from lead-in moves to lead-out moves, or vice versa.  This productivity enhancement speeds up programming, reduces mouse clicks and decreases the chance of making an error.
A new option to make programming of more complex machines much easier is the NC Program Viewer function.  This allows improved analysis of the NC code generated by PartMaker to help achieve optimum productivity from the machine.  It also includes unique functionality for automatically aligning “wait” or “sync” codes for multi-channel machines.
By simply clicking the “Align Wait/Queue Commands” button, the user can quickly see which processes are being executed simultaneously across a multi-channel CNC program and so identify opportunities for a more efficient sequence of operations.  This functionality can be applied automatically to a broad spectrum of combinations of machine controls with multi-axis turn-mill machines and Swiss-type lathes.
PartMaker’s extensive tool database now includes explicit ions for tapered end-mills as well as neutral turning tools and back-turning tools.  Additionally, the software now automatically gives users the option to choose between a flat-bottom, bull-nose or ball-nose end-mill when creating a new end-mill.  The use of back-turning tools and tapered end-mills is available as a free upgrade to maintained licensees of PartMaker’s Advanced Tools option.
