hyperMILL® is the benchmark for automotive OEM
Added to MTDCNC by OPEN MIND on 22 April 2016
BMW AG has introduced OPEN MIND Technologies, developer of the hyperMILL® CAM system as one of its CAD/CAM software suppliers. Following multi-phase benchmark tests, the modular hyperMILL® complete CAM solution successfully won over the IT department and the experts in tool engineering, prototyping and series production at the BMW Group. As a result, BMW departments and plants all over the world can now use the high-end hyperMILL® CAD/CAM system.
The results of the benchmark tests revealed that thanks to the exceptional advantages of the hyperMILL® CAM solution, BMW AG has introduced OPEN MIND as a permanent CAD/CAM software supplier. The IT department, the specialist tool engineering and prototyping departments as well as serial production departments see hyperMILL® as an intuitive, high-end CAD/CAM system with a high degree of technical fulfilment. BMW plants around the world can now select and employ hyperMILL® in consultation with IT headquarters.
The selection process
Little over 18 months ago, the central IT department of the BMW Group began searching for a new CAD/CAM system. The goal was to find a CAD/CAM solution with a high level of coverage for the many different NC application areas in the numerous specialist departments. This resulted in a comprehensive technical evaluation of CAM vendors and a cost-benefit analysis for all participants in the benchmark tests.
Intensive benchmark tests
In the autumn of 2014, the BMW Group invited OPEN MIND and five other CAD/CAM manufacturers to take part in benchmark tests. A multi-phase selection procedure saw the CAD/CAM systems undergo intensive testing in the following main categories: ‘tool making’, ‘series production’, ‘prototyping’ and the internal BMW category ‘CAM light’. This was followed by a technical evaluation based on presentations and programming tasks. To make the shortlist, the system had to successfully pass the economic evaluation. OPEN MIND came out on top thanks to the technical and economic benefits of hyperMILL®. This cleared the way for the pilot phase with milling tests in early 2015. Users from the specialist departments at BMW GmbH material testing departments and at the tooling divisions in Munich and Dingolfing were provided with training and began to use the OPEN MIND system to programme components and tools.
High standards
hyperMILL® is a modular CAM solution that integrates a comprehensive concept for 2D, 3D as well as 5-axis milling, mill/turning and machining operations like high-speed and high-performance cutting (HSC and HPC) in one interface. Complete machining with just one CAM package and one post-processor for all turning and milling processes, now results in integrated processes and minimised machining times for BMW.
Automated CAM programming
Automation represents the highest degree of perfection in CAD/CAM systems. At BMW, the trimming dies for the automation task were selected in the benchmark tests. The task was to create NC programs automatically for ten trimming dies. “We defined an optimised process for these trimming dies and at the push of a button, it’s possible to reproduce these best practices on any of these geometries,” says Martin Herrmann, Product Development Manager at OPEN MIND. “In terms of automation, we can significantly reduce programming times and also create NC programs that guarantee perfect, highly optimised machining quality,” adds Volker Nesenhöner, CEO at OPEN MIND Technologies AG. The programming times and milling results won over the specialist departments at the BMW Group.
