Vero To Demonstrate Three Of The Best At MACH
Vero Software will be demonstrating the 2018 R1 releases of Edgecam, Radan and VISI, at the forthcoming MACH Exhibition.
Edgecam includes updates to roughing cycles for milling, turning and MTM. And the prevention of unnecessary CAM regeneration is seen as being particularly important. When editing a tool command, the remaining instructions will no longer be automatically regenerated if the alteration does not affect the corresponding cycles with aspects such as coolant or high-speed.
Sheet metal software Radan takes the increasing popularity in automatic bending into consideration, making fingerstops safer by allowing for improved part alignment in the press brake, and reducing the number of fingerstop movements required between bends. A new batch nesting system could improve material usage by around nine percent over a year with a revolutionary approach to optimising a range of nests, by looking at the entire nest run and reducing the number of overall sheets instead of focusing on how full each individual sheet is.
For the mould and die market, VISI provides greater flexibility when constructing supplier and non-standard tool configurations. Customisable templates, including the management of blank and predrilled plates, allow for easy tool layout creation and enhanced editing throughout the design process.
Edgecam, Radan, VISI, MACH, April 9 – 13, NEC, Birmingham, Stand 430, Hall 18.
More from Hexagon Manufacturing Intelligence
