WorkNC’s Latest 2016 Version Is Out Now
Added to MTDCNC by Vero Software on 12 July 2016
CAM Software solution WorkNC have just launched their latest 2016 version, which
integrates Vero Software’s innovative Waveform technology to reinforce its key assets of toolpath reliability, time savings, cost reduction and high surface quality.
Miguel Johann, WorkNC Product Manager, says: "Our Development Team worked tirelessly for the past 12 months to bring us WorkNC 2016, a version based on more modern technologies, from the tools we use internally and the methodology we use to develop software, to new manufacturing techniques like Vero's Waveform constant cutter engagement and Vero's Client License Server, CLS. WorkNC 2016 offers more stability and reliability to the everyday use of WorkNC, increasing the comfort of our users with ergonomic improvements to the product's interface."
Improved productivity and longer tool service life
The Waveform technology, developed over several years by Vero Software, significantly improves standard roughing strategies by removing a consistent amount of material while preserving machine and tool service life.
In order to maintain a constant load on the cutter, the strategy consists of machining from the stock material towards the part geometry. This approach results in a reduced number of intermittent cutting movements, especially in the outer areas, meaning that the tool stays engaged in the material for as long as possible and leads to fewer retracts and air cutting periods.
The stepover distance automatically adjusts in order to maintain a constant load on the cutter over the complete toolpath trajectory, making it possible to maintain optimal feed rates during the whole cycle, which can attain rates of up to 5 times faster than a traditional roughing strategy. Machining is performed over the full cutting length of the tool (whenever possible) which distributes load evenly.
Quality drives Productivity in WorkNC 2016
Combined with the WorkNC Collision Detection module, which allows detecting collisions and out-of-limit conditions in the whole machining environment, the Waveform technology offers highly secured and reliable toolpaths that improve quality while maintaining high productivity level.
Still aiming at reducing time cycles and improving surface quality, WorkNC 2016 enhances its Wall Machining strategy with a Lace cycle used with the appropriate tools.Without this Lace option, machining is done from top to bottom, and the tool moves up in rapid feed rate. With the Lace option, the first pass is done from top to bottom, and the next pass is done from bottom to top. The toolpath is shorter, with less retracts, machining time is therefore reduced.
Greater user friendliness
In WorkNC 2016, it is now even easier to select the different commands in the graphical user interface and commands are now at the users' fingertips. The WorkNC 2016 interface is more intuitive thanks to graphic symbols representing calculated operations.
WorkNC Auto 5 availability
In version 2016, the Auto 5 technology; a real advancement in the domain of 5 axis machining, is now available as a standard module.
Thanks to Auto 5, users can automatically generate 5 axis toolpaths based on existing 3 axis toolpaths while also taking into consideration the kinematics of the selected 5 axis NC machine. Engineers can convert 3 axis and 3+2 axis toolpaths into simultaneous 5 axis toolpaths.  Programming can be done directly in the workshop. The intelligent toolpaths are dynamically and automatically checked in order to avoid collisions and manage the linear and rotational limits of the machine.
The Auto 5 technology allows the use of shorter, more rigid cutters allowing most of the part to be finished in one single operation. The use of this module facilitates the finishing phase of a project.
Headquartered in England, Vero Software designs, develops, and supplies CAD/CAM/CAE software radically enhancing the efficiency of design and manufacturing processes, providing its customers with exceptional value through high productivity gains and significantly reducing time to market. he company’s world-renowned brands include Alphacam, Cabinet Vision, Edgecam, Machining STRATEGIST, PEPS, Radan, SMIRT, SURFCAM, WorkNC and VISI, along with the production control MRP system Javelin. Despite the diversity of application, these solutions have one thing in common:  they all address the rising challenges of achieving manufacturing efficiencies and bring huge value to the operations in which they are deployed.
Vero has offices in the USA, UK, France, Germany, Italy, Spain, Netherlands, Japan, China and South Korea. Products are distributed through a comprehensive global reseller network across more than 45 countries. Vero is part of the Hexagon Group (OMX Nordic Exchange:  HEXA B), a leading global provider of design, measurement and visualization technologies that enable customers to design, measure and position objects, and process and present data.
