10 litres/min aluminium cutting with Starrag STC 800X!
Added to MTDCNC by Starrag UK Limited on 01 February 2016
Using a 30,000 revs/min 120 kW spindle, the Starrag five-axis machining centre can remove aluminium at the rate of up to 10 litres a minute.
But that’s not the only feature that sets this machine apart from others because, with an A axis range of -110 deg/+60 deg, no angle heads are necessary for completing a wide range of complex machined features in a single set-up.
In addition, up to 465 tools can be held in the automatic toolchanger, tombstone fixturing permits multi-parts machining with no downtime and the machine can easily be integrated into an FMS.
Accommodating pallets of 800 mm by 1,000 mm and workloads of 2,000 kgs, the STC 800X has a maximum workpiece swing diameter of 1,400 mm and feed rates of 60 metres/min in the X, Y and Z axes.
