Deephole drilling to 40xD from KOMET GROUP
Added to MTDCNC by KOMET (UK) Ltd on 30 June 2015
Whereas the KOMET KUB® Drillmax "normal" range of solid carbide drilling tools in diameters from 3.0 to 16.0 millimetres and in lengths/diameters ratios 3×D, 5×D and 7-8×D are already available, the precision tool manufacturer has developed an XL standard range of tools for deep-hole drilling. The expertise gained from developing many special solutions has been incorporated in the tools of the KOMET KUB Drillmax XL series, which is available ex stock for 12×D in the diameters of 3.0 to 12.0 mm, for 20×D in the diameters of 3.0 to 10.0 mm and for 30×D in the diameters 3.0 to 8.0 mm.
For the XL variants, the tool geometry has been adapted to the requirements of deep-hole drilling. The spiral-fluted deep-hole drills are provided with four lands to ensure a high degree of drilling and alignment accuracy. Optimised, special flutes guarantee ideal chip removal. In addition, the tools undergo a special surface treatment and are provided with a coating which has already more than proven itself in the manufacture of KOMET® special tools. As a result, KOMET KUB Drillmax XL tools enable drilling with process reliability to a depth of 30×D without pecking, whereby high feed rates and cutting speeds promote short manufacturing times.
A speciality that can supplied on request is the KOMET KUB Drillmax XL ALU 40×D, a high-performance drill with a cutting edge and flute geometry specially matched for aluminium. Thanks to the additionally polished flutes, chips are reliably transported out of holes to a depth of 40×D.
The KOMET GROUP is one of the leading single-source suppliers of precision tools and has been at the forefront of innovation in the sector for over 90 years. The internationally successful group, based in Besigheim, sees itself as more than simply a tool manufacturer. Rather, it sees itself as a provider of innovative ideas. With exemplary creativity, the company develops, produces and markets customer-specific solutions and premium products for all stages of production. The KOMET GROUP currently employs more than 1,600 staff in its 20 subsidiaries and is represented in around 50 countries.
