Eltool Corporation have done it again....
Added to MTDCNC by PTS Ltd on 09 July 2015
To further the possibilities of machining with right angle heads, the Titespot coolant driven program available from the UK's exclusive distributor, Pro-active Technical Solutions Ltd, now allows machining into bores as small as 16mm dia.
Not only are the Titespot heads unique in allowing full 360 deg spindle orientation with a right angle head for multi positional machining, getting into confined areas has just been made even easier.  Keeping the size "0" head inline with its siblings, the size "0" head is modular so fitting to live lathe tooling allows small bore internal machining such as oil way groove machining or keyway cutting, greatly reducing machining cycle times and consumable costs.
Contact Pro-active Technical Solutions Ltd or see www.proactive-tech-solutions.co.uk to see how Titespot through coolant right angle heads can help solve your machining problems.
