Guhring Develops New Fine-Boring Line
Added to MTDCNC by Guhring Ltd on 05 September 2016
As if Guhring didn't already have one of the industry's most comprehensive holemaking lines; the Birmingham Company is now introducing a new line of precision boring tools to extend the line even further..
Available for precision boring of holes from 44 to 130mm diameter, Guhring is now introducing its impressive Hollfelder GA200 Vario range of boring tools. This truly universal boring system can deliver micron precision adjustment for particularly fine boring operations whilst simultaneously providing a platform for more robust rough boring operations through a choice of different boring heads and corresponding insert geometries and grades.
With a large adjustment range and different holders for rough and finish boring, the GA200 Vario is the only boring tool you'll ever need. Adding a rigid connection between the basic adaptor and the interchangeable insert holder, the GA200 Vario can easily be adapted to all types of machine tool, spindles, tool lengths and bore depths.
The flexibility of the toolholding system is matched by the remarkable range of insert geometries and coatings that can be ordered according to customer specifications. This diverse insert geometry and grade availability makes the GA200 applicable to virtually all material types and cutting conditions. Furthermore, the design of the cutting head incorporates unequal 170 degree cutting edge spacing and this increases material removal rates and eliminates the possibility of retraction marks that are commonplace with many inferior boring systems.
If you want to improve your boring performance and reduce your tool inventory by using just one boring system, contact your local Guhring dealer for more details..
