Guhring PowerTaps now includes Form E and more..
Added to MTDCNC by Guhring Ltd on 20 August 2014
Guhring PowerTaps - Pricing here
The new Guhring PowerTap program contains a selection of 22 different types of tap for thread types that include ISO Metric, Metric Fine, UNC, UNF & BSP threads.
Suitable for tapping general steels, cast steels, high tensile and alloyed steels and even stainless steels or aluminium, the new line of Guhring PowerTaps is a genuine all-rounder.
The impressive line of new taps from Guhring are a high quality product line that is stocked in depth in the UK and available through your usual dealer. The range provides the customer with an excellent price to performance ratio and furthermore they are available on short lead times to meet the needs of the end user. The PowerTap is available in a variety of types to suit through and blind hole machining with external and internal coolant supply and a wide range of coatings for the numerous ranges to ensure the customer achieves maximum performance and thread quality. Available with left and right hand cutting, the PowerTap line can cater for threads from M2 to M24 depending upon the tap selected.
In addition to the conventional Form B and C for machine taps, Guhring is including Form E tools in its standard PowerTap range. By doing this, Guhring is taking into account the increasing demand for taps whereby threads can be produced as close as possible to the bottom of the bore when machining blind holes and to produce the deepest threads possible when machining through holes.
