Improving Tool Life with New CVD Turning Grade
Added to MTDCNC by Taegutec on 22 August 2016
The machining of cast iron material has a tendency to deviate during operation due to the nature of the material. Moreover, the usage of ductile cast iron has grown as a trend and has become more pervasive as a material of choice in every industry. In order to respond to these two machining conditions, TaeguTec has launched the improved TT7015 Life+ CVD grade for turning operations.
The advanced coating and substrate design of TaeguTec’s new TT7015 Life+ enables improved wear resistance and toughness during the machining of parts made from cast iron. The improved grade provides higher stability on a wide range of applications and generates longer tool life due to the grade’s anti-chipping capability.
The new TT7015 Life+ grade is specifically geared towards general purpose machining of gray cast iron and ductile cast iron materials. Furthermore, the TT7015 Life+ grade minimizes unexpected insert failure even under interrupted cutting conditions while offering excellent surface roughness during machining due to its fine coating layer.  During the testing phase of the TT7015 Life+, the new grade increased tool life by as much as 117 percent.
While working on disk brakes made from gray cast iron, the TT7015 Life+ increased tool life by 100 percent while performing facing operations. On a front hub made from ductile cast iron, the new grade increased tool life by 98 percent. But the big eye opener came with the internal roughing test on a differential case cover made from ductile cast iron which increased tool life by an amazing 117 percent. For more information or to locate a TaeguTec professional engineer that can offer expert advice about the proper tool for the job, visit www.taegutec.com
