Holemaking is no bore with new heads from ITC
Tamworth cutting tool manufacturer Industrial Tooling Corporation (ITC) has further enhanced its world-leading portfolio of bore…
Now available from Industrial Tooling Corporation (ITC) is the new BIG KAISER C-Cutter Mini, an ultra-fast compact chamfer cutter for improving productivity, precision, surface finishes and tool life.
Designed and developed by BIG KAISER a global leader in premium high-precision tooling systems and solutions for the metal-working industries, the new C-Cutter Mini is designed for multi-functional cutting tasks, including chamfering, back chamfering and face milling.
Compared to competitor products, the tool's market-leading speed and feed rate capability has the potential to slash machining times by up to 85%. This remarkable productivity improvement is credit to the tool's innovative design that reduces the cutting diameter down to the lowest limit. This enables impressive ultra-high spindle speeds and feed rates. Cutting speed is further increased by the new wear-resistant inserts with multi-layer Physical Vapour Deposition (PVD) coating.
Available in single insert and four insert configurations, the C-Cutter mini provides additional flexibility for the customer. Increasing the number of inserts from one or two per cutter to four, multiplies the feed rate and this significantly speeds up operations and improves productivity. The new C-Cutter Mini that is available in the UK from ITC also marks the introduction of the world's smallest hex insert, with a diameter of 3.97mm. This particularly small dimension enables highly-efficient back chamfering from a 6mm starting hole diameter, whilst the 3-corner insert design reduces costs.
According to Giampaolo Roccatello, VP Sales at BIG KAISER: "The new C-Cutter Mini delivers a 'triple effect', essentially compounding the benefits of the four inserts. It delivers faster feed rates and the reduced diameter raises the spindle speed whilst the new PVD coating enables higher cutting speeds. This tool is a prime example of how BIG KAISER's focus on innovation consistently delivers tangible results to our customers."
For further details on how the new BIG KAISER C-Cutter from ITC will enhance your machining performance and productivity, please contact an ITC representative or visit: www.itc-ltd.co.uk
