Holemaking is no bore with new heads from ITC
Tamworth cutting tool manufacturer Industrial Tooling Corporation (ITC) has further enhanced its world-leading portfolio of bore…
For machining applications that generate significant levels of swarf, Industrial Tooling Corporation (ITC) Ltd has now introduced the new Chip Fan from BIG KAISER. The innovative new Chip Fan from BIG KAISER is a tool that offers a fast and safe method for removing chips and coolant from the work envelope without stopping production.
The blades of the Chip Fan are turned by the spindle on the machine tool. With a finely balanced design, the new Chip Fan operates at spindle speeds up to 12,000rpm to provide powerful, high-volume air cleaning. This is efficiently achieved without any of the dripping coolant and flying chip issues that are associated with conventional air hose blasts.
To ensure its long life and durability, the BIG KAISER Chip Fan is manufactured from a high-strength anodised aluminum. Furthermore, the chip fan comes with a pre-drilled hole that allows through coolant spindles to distribute coolant through the centre of the fan to rinse off tables, fixtures and workpieces. Following this cycle, the fan runs at a high speed to remove any remaining chips or coolant, thus performing two cleaning operations in a single step. Ideally, the Chip Fan should be programmed into the machining cycle to minimise spindle downtime and maximise operator efficiency. Safety is also improved as all the swarf and coolant is neatly contained within the machining enclosure and kept off the shop floor.
Commenting upon the arrival of this new system, Mr Giampaolo Roccatello, VP for Sales at BIG KAISER says: “Keeping production equipment clean significantly improves reliability and quality while also ensuring a quieter working environment. Our new Chip Fan means chips and coolant can be quickly and easily removed without any interruption to production. This maximizes productivity and prevents unpleasant costly delays.”
For further details on the new Chip Fan and how to keep your machine clean whilst maximising uptime and utilisation, please contact ITC.
