ITC Introduces World’s Smallest Hydraulic Chuck for HSK-E25 Spindles
Added to MTDCNC by ITC LTD on 31 March 2017
Industrial Tooling Corporation (ITC) has now launched the world's smallest hydraulic chuck for HSK-E25 machine spindles into the UK marketplace. Manufactured by BIG KAISER, a global leader in premium high-precision tooling systems and solutions, the new line of chucks completes the extensive range of BIG KAISER Super Slim hydraulic chucks.
The Super Slim Hydraulic Chucks (HDC) line are the perfect tool holders for precision finishing processes in confined areas with drills, reamers, ball mills, end mills, diamond reamers and grinding tools. The wide variety of clamping diameters and projections are ideally suited for practically all applications in the automotive, aerospace, medical, and mould & die sectors.
BIG KAISER designed the Super Slim HDC to require only a single wrench for clamping and unclamping. These chucks can clamp ultra small tools directly. Without needing a reduction sleeve, the chucks can clamp down to a diameter of 3mm. When clamping diameters of 3mm, the external diameter of the chuck nose is a mere 14mm. At a length of 90mm the diameter is just 25mm – this slender design means that interference contours should no longer pose a problem.
"Our HSK-E25 tool holder line-up now includes BIG KAISER's high precision, low runout, hydraulic chucks. These ultra-precise hydraulic chucks with their extremely slim design are perfectly suited for high precision finish milling operations on ultra-high speed spindle machine tools with small work envelopes," says Peter Elmer, CEO of BIG KAISER.
The Super Slim HDCs for the HSK-E25 machine spindles are now available for the HSK-E 32/40/63 and BBT 30/40/50 spindle model lines. For further details on how ITC can enhance your small component machining processes with the HDC line, contact your local ITC representative now.
