New Ceramic Grades for High Temperature Alloy Machining
Added to MTDCNC by Taegutec on 27 June 2016
The demand for cutting tools to improve productivity and cut the cost of machining high temperature alloys is always increasing, that is why TaeguTec has now launched two new SiAlON ceramic grades - the TC3020 and TC3030.
Offering superior performance, both the TC3020 and TC3030 ceramic grades are suitable for high temperature alloy machining where difficult-to-cut materials such as Inconel, Rene and Titanium are used. These ceramic grades are characterised by their excellent toughness and anti-chipping capabilities making them the best choice for both interrupted and continuous machining.
With the introduction of both these grades, TaeguTec has increased its range of optimal solutions for machining high temperature alloys beyond its existing whisker ceramic grade. The new grades are available for insert lines in turning, milling and grooving applications.
The TC3020 is ideal for high temperature alloy machining and runs at the same conditions as the whisker ceramic grade. Its superior wear resistance is due to its high stability while it offers better flank and notch wear resistance compared to the competitor’s similar grade. Furthermore, the TC3020 has excellent high temperature strength and fracture toughness.
The other new offering, the TC3030 is also created to handle high temperature alloys with the difference being that the extreme toughness generates higher feed and heavier depth of cut potential. This suits the machining of scaled parts and roughing applications while offering excellent thermal shock resistance and thermal conductivity.
By combining silicon nitride and aluminum oxide, TaeguTec’s SiAlON grade offers incredible chemical stability in order to reduce notch wear in demanding operations. It also has the capability to run at 4-6 times the speed of conventional carbide inserts.
While performing a continuous grooving operation on an engine casing made from Inconel 718, the TC3020 grade’s productivity increased by 40 percent over the competitor’s similar ceramic grade. For an engine casing made from the same Inconel 718 with external interrupted turning and interrupted grooving operations, TaeguTec’s TC3030 increased tool life by 23 percent and 56 percent respectively. The biggest improvement over the competition was on a Rene 108 material, the TC3030 performed incredibly well on a face milling operation of a shroud workpiece when it increased tool life by 100 percent.
For more information concerning TaeguTec’s cutting tools and industrial products, or to locate a dealer nearest you, visit www.taegutec.com
