Rainford is the 'Expert' for Drilling
Added to MTDCNC by Rainford Precision on 01 March 2016
Rainford Precision may well be regarded as the expert in micro machining, but now it's taking this mantle to the discipline of drilling with its new 370 Expert Series of micro drills from Louis Belet.
The new 370 Expert drilling range from Louis Belet is suited to stainless steel drilling and is available in diameters as small as 0.5mm up to 1.5mm in 0.01mm increments. This extremely precise drilling range is also offered from 1.5 to 3mm diameters in 0.05mm increments. So, if you are in the micro machining market and you are conducting small hole diameter drilling, the 370 Expert range from Rainford Precision should be your first port of call. This comprehensive diameter range is now available from stock from the St Helens based micro machining specialist.
The new 370 Expert drills incorporate the Louis Belet Nemo coating, which makes the micro drills suitable for drilling stainless steel and difficult to cut titanium alloys. The 370 Expert drills incorporate a 135 degree point angle and an innovative geometry design that enables the 370 Expert drills to carve through the toughest of materials with extreme ease. Furthermore, the overall drill length and flute length of the range has been optimised to ensure every diameter demonstrates maximum rigidity, hole concentricity and performance levels. For further details on how Rainford can solve your micro machining and drilling issues, please contact us via our new website www.rainfordprecision.com
