CoroMill Plura end mills available from Turner Tools
Added to MTDCNC by MTDCNC on 09 June 2015
When it comes to selecting a cutting tool for a specific component or application, the choices can often prove overwhelming. That was until Turner Tools introduced the new Sandvik Coromant range of CoroMill Plura end mills. This new product line enables the customer to find their desired choice with ease, whether it's an optimised tool for a specific material or one that performs well in many materials.
The range of Sandvik Plura tools from Turner Tools includes high-performance solutions for high speed machining, die-making and high feed machining that encompasses everything from heavy roughing to super-finishing in most materials.
 The CoroMill Plura line-up from Turner Tools provides optimised tools with geometries and grades for specific materials and applications that can maximise production output per time unit. This is combined with flexible tools that are designed for high performance and secure machining in a variety of materials, applications, component sizes and shapes, allowing maximum machine utilisation.
Forming part of the CoroMill Plura range is the solid end mill series that have optimised grades for all materials and conditions, cylindrical, Weldon and iLock shank options with straight, conical and t chip-dividing cutting edge tool shapes. Furthermore, customers can select end mills with or without neck, undersized shanks, PCD tipped end mills with internal coolant and four grades for different ISO material groups.
For processes such as slotting, Turner Tools can supply heavy duty end mills with an extremely tough grade and optimised flute shape for effective chip evacuation with full slot milling up to two times the diameter. For shoulder milling, the Sandvik Plura end mills with unequal helix angle for stability and excellent surface finish in high feed side milling operations are a superb choice. To complete parts with profile milling tools, Turner Tools can offer a wide range of ball nose end mills for all materials, including small cutter diameters down to 0.1 mm (0.004 inch), suitable for die and mould manufacturing where high precision is important.
The extensive Plura range from Turner Tools also includes a diverse line of chamfering tools for 45-degree and 60-degree chamfers whilst thread milling is catered for by a comprehensive range that includes metric threads as well as UNC, UNF, NPT and NPTF available as options.
