Seco introduces new M06 insert geometry to Turbo 10 series
Added to MTDCNC by Seco Tools (UK) Ltd on 22 July 2014
Seco has launched the new M06 geometry as part of its Turbo 10 Square shoulder milling range of inserts. The new geometry delivers high productivity and is a cost effective solution for the machining of Stainless Steels and titanium alloys.
The new M06 geometry, part of the company’s XOEX10T3 insert range, is now available in grades F40M, T350M, MP2500, MP1020, MM4500, MS2500 and MS2050, and with corner radii from 0.4 mm to 3.1 mm.
All Turbo 10 cutters feature precision milled pocket seats that improve run-out, stability and tool life by providing stable and rigid contact between the tool body and insert.
The tools have through-coolant channels that improve productivity, reduce heat generation and ensure excellent chip evacuation.
Turbo 10 cutters provide precision component manufacturers with a reliable and flexible solution when machining tough materials and are the number one choice for slotting, shouldering, ramping, facing, pocketing, plunging and turn milling operations.
In addition to the new M06 geometry, the series also includes a wide variety of direct-pressed and ground insert options.
What are you looking for?
What is 1 + 7? (Spamcheck)
