Seco extends its 335.25 disc milling cutter range with new insert sizes.
Added to MTDCNC by Seco Tools (UK) Ltd on 01 December 2015
Seco Tools has introduced two new insert sizes to its popular 335.25 range of disc milling cutters.
The new additions mean that Seco’s 335.35 cutters are now available in cutting widths from 13.5mm to 32mm.
Seco’s 335.25 disc milling cutters provide manufacturers with high productivity and flexibility and can perform numerous machining operations – e.g.  Slotting, back facing, helical and circular interpolation and plunging etc.
The tools exhibit a unique cutter design and four-cutting-edge insert geometry that helps reduce cutting forces and optimise chip flow. The range features fixed-pocket and adjustable-width tools making them ideal for all types of machining environments.
Available in diameters from 80 to 315 mm, the 335.25 range includes 15mm, 20mm and 25mm cutting widths for fixed-pocket disc milling cutters and 13.5-mm to 32-mm cutting widths for adjustable-pocket cutters.
Inserts are offered in four different sizes with corner radii ranging from 0.4 mm to 6 mm and, with a number of insert grades available, allows 335.25 tools to be used to machine all material types.
