View by company
View by company
View by company
Seco’s Turbo 10 square shoulder milling cutter range is expanded
Seco Tools (UK), the leading manufacturer and supplier of complete machining solutions to the metal-cutting industry has significantly expanded its highly-successful Turbo 10 square shoulder milling cutter product line with the introduction of new Turbo 10 inserts with new geometries and radii, and a new range of helical cutters.
The inserts are now available with corner radii ranging from 0.4 mm to 3.1 mm and new geometries for the range of ground inserts have been introduced. These provide manufacturers with increased performance and process reliability when machining materials that provide specific challenges, such as aluminium, stainless steels, titanium alloys and other difficult-to-machine alloys.
The new Turbo 10 helical range is the ideal solution for helical shoulder milling operations that require process stability, flexibility and high precision.
Turbo 10 helical cutters are available in diameters ranging from 20 mm to 54 mm and include Weldon, Seco Weldon, Combimaster heads, Seco-Capto and Arbor mounting options.
All cutters in the Turbo 10 family include precision milled pocket seats that improve run-out, stability and tool life by providing optimal contact between the tool body and insert. Integrated through-coolant channels support high productivity whilst also delivering excellent chip evacuation.
Highly flexible, Turbo 10 cutters can be used for slotting, shouldering, ramping, facing, pocketing, plunging and turn milling applications.
Published on MTD CNC by on 19 February 2013
Have you seen these videos all relating to ?
Latest products added to MTDCNC
Enquire with MTD CNC TODAY
Spam check: What is 1 + 7?
