TaeguTec End-Mills are just diamond!
Added to MTDCNC by Taegutec on 05 September 2016
With the rapid emergence of CFRP materials, TaeguTec has extended its diamond coated and PCD tooling lines to reflect the industry trend toward strong lightweight materials. This now includes the recent launch of the new RRFE Series of end mills for rough machining composite materials.
The new RRFE Series is a solid carbide range of end mills with a diamond coating for processing abrasive CFRP materials. Unlike competitor cutting tools that use a Diamond Like Coating (DLC), TaeguTec applies its TTD610 diamond grade. As a true diamond grade, the RRFE Series delivers tool life up to 4 times longer than DLC coated tools from alternate vendors. The RRFE router tool eliminates delamination by operating with low cutting forces and less vibration, a direct result of the innovative geometry design.
Primarily designed for profiling composite plate materials, the RRFE Series has a particularly long 15 degree helix flute that enables end users to utilise the complete flute length for side cutting composite plate materials. The new RRFE Series is available in diameters of 4, 6, 8, 10 and 12mm with 6, 8, 10 and 12 flutes respectively. To enhance tool life and longevity when side cutting, the RRFE is available with flute lengths of 12, 18, 24, 30 and 36mm on an overall shank length from 50 to 100mm depending upon the chosen diameter. For further details on this impressive new diamond range of end mills, contact TaeguTec on Tel: 01937 589828.
