Tough PVD Grade for Turning High Temperature Alloys
Added to MTDCNC by Taegutec on 18 July 2016
TaeguTec has now unveiled the TT8080, an excellent PVD coated grade for superior performance  when turning stainless steel and high temperature alloys. The TT8080 grade has been adapted to turning applications and is particularly well suited for stainless steel and the machining of high temperature alloys under low cutting speeds and interrupted cutting conditions.
Characterised by excellent toughness and high anti-chipping capability, the TT8080 grade is the perfect choice for interrupted and rough machining. Compared to the existing TT8020 grade, the new TT8080 grade guarantees longer tool life and higher machining stability due to improved wear resistance. The strong coating adhesion on the TT8080 is not only is crack resistant but also eliminates delamination.
Product testing on different forms of machining resulted in incredible increases of tool life over the competition. Most notably, while conducting an interrupted facing operation on a valve body, TaeguTec’s TT8080 PVD coating increased tool life by a whopping 160 percent. On another test, the new coating increased tool life by 71 percent on an external interrupted operation. For external continuous machining of a ring on SUS316, TaeguTec’s TT8080 PVD coating increased tool life by 33 percent over the competition. For more information regarding this and other TaeguTec tools, or to locate a dealer nearest you, visit www.taegutec.com
