These new high-feed milling cutters from Tungaloy are making people a lot of money!
If you thought you couldn’t run a high feed, here’s the proof that you can! Tom…
Tungaloy now offers a thread milling head line for TungMeister – a high efficient exchangeable-head endmill series, to further expand its flexibility in a wide range of thread milling markets.
Thread milling creates threads with the helical interpolation movements of a tool in machining centers and multi-tasking machines. Unlike the conventional tapping method, thread milling produces low cutting forces and facilitates smoother chip evacuation. As far as the pitch matches, one multipoint thread mill can machine a wide range of diameters; while one single-point mill can address a variety of pitches and diameters, both which help to minimize tool inventory. The tool indexing is made simple due to its modularity, substantially reducing machine downtime and improving cycle times.
At a Glance
Available thread sizes:
Multipoint, full-profile thread milling heads
ISO metric (Pitch: 0.75 mm – 3.0 mm)
Unified threads (8-24 TPI)
Whitworth (11-19 TPI)
Single-point, partial profile thread milling heads
60° partial (Pitch: 0.5 mm – 4.5 mm)
55° partial (11-14 TPI)
Reduced machine downtime due to simplified tool indexing
Wide selection of shank types
Steel shanks
Tungsten carbide shanks
Pure tungsten shanks with through-coolant
Total items to be added: 25 heads
