Sandvik Corochuck is now offered by Turner Tools Ltd
Added to MTDCNC by MTDCNC on 07 August 2014
With outstanding pull-out security the new CoroChuck 930 chuck from Sandvik has been designed to eliminate vibration to deliver excellent stability and accessibility in all milling and drilling operations. Covering all machine interfaces, the new CoroChuck 930 helps to maintain efficient production through quick and easy tool set-ups and changes.
This patented spindle system can achieve a run-out precision of <4microns at 2.5 × DC. Claiming the best pull-out resistance on the market, Sandvik Coromant believes this claim is substantiated by the design of the brazed clamping membrane that promotes ultra-secure clamping with supports on either side.
The result is a lower risk of tool pull out with the CoroChuck 930. Furthermore, it provides high metal removal rates that increase productivity whilst the secure clamping process guarantees safe machining. In addition, the CoroChuck 930 provides quick tool changeovers and set-ups and it also improves accuracy and surface finishes.
What are you looking for?
What is 1 + 6? (Spamcheck)
