WNT migrates Dragonskin coating to rotating tools
Added to MTDCNC by WNT (UK) Ltd on 26 August 2015
Since the introduction of the Dragonskin coating for indexable cutting inserts, the advantages of WNT’s innovative coating technology have become apparent, with customer feedback highlighting significant increases in tool life due to less wear and a strong performance. It was a logical move, therefore, to take the next step and also coat rotating tools with Dragonskin technology – the universal WTX-Uni solid carbide drill series is the first recipient.
The development and introduction of the Dragonskin coating technology has enabled unprecedented levels of performance for indexable milling and turning systems and WNT is now applying those benefits to its drilling systems, which are being upgraded with this extremely hard and almost impenetrable surface coating. The WTX-Uni drill is the first to receive this treatment as it is one of the most popular universally applicable drills in the WNT product range. "Thanks to this special coating, the WTX-Uni will perform even better and, it can be used at a significantly higher cutting data. In test results the at WNT’s Technical Centre in Kempten we found that the tool life increased by up to 40 %, exceeding our highest expectations," says WNT’s Product Manager, Wolfgang Schneider.
The WTX-Uni with Dragonskin coating was well received recently when it was unveiled during a customer event co-hosted by WNT Germany and its partner DMG MORI. A practical demonstration of the new WTX-Uni enabled customers to see the unique performance of the drill in action for the first time and the reaction was extremely positive.
While the visual appearance of the Dragonskin coating with its gold colouration is obvious, it is at the microscopic level where the coating is even more impressive. The combination of the Dragonskin coating, carbide substrate and drill geometry deliver tremendous resilience and high levels of wear protection that allow for elevated cutting speeds and elongated tool life, making the WTX-Uni drills ideal for applications where high speed and process security are a priority.
As the name implies the WTX-Uni has a wide application range across steel, stainless steel and cast iron components and is available in a diameter range of 3 – 25 mm with three standard shank styles available (HA, HB, HE).
"With these features the WTX-Uni drill is a true all-rounder that will fulfil the highest demands of industry. With the addition of the Dragonskin coating the WTX-Uni easily outperforms its predecessor, with longer tool life and improved performance and in line with WNT’s drive to reduce manufacturing costs for its customers this higher performance is available at the same price as the original WTX-Uni drills," says WNT (UK) Managing Director, Tony Pennington.
Any customer wanting additional information on the WTX-Uni range, or a machining demonstration, should contact their local Technical Sales Engineer, for new customers a Technical Sales Engineer visit can be organised by contacting our sales office on 0800 073 2073.
