1000 SR from PH-Cleantec available via Lubriserv
Added to MTDCNC by Lubriserv Limited on 15 August 2014
The new 1000 SR PH-Cleantec series of component cleaning systems are the only choice for fast, flexible and efficient cleaning of your parts.  With a water sump, cleaning surface and splash tray, the mobile units are ideal for cleaning machined components and machine parts as part of a maintenance program.
The innovative new systems from Lubriserv use machine coolant or water and heat it to 95 degrees C to clean components with a low pressure jet system that gives virtually no spray back. The beauty of this remarkable new system is that it can be easily wheeled around the workshop as it is a fully mobile unit.
The ability to move the 1000 SR from location to location or machine to machine around any engineering facility to clean components or machines , makes this a truly unique innovation.
Furthermore, with no chemicals required the PH Cleantec SRE 1000 from Lubriserv is a safe and efficient cleaning device that saves time and money for the customer whilst improving the aesthetics of the finished parts.
LATEST PRODUCTS FROM Lubriserv Limited
