Quick change-over CentroteX workholding interface from Hainbuch
Added to MTDCNC by HAINBUCH UK Ltd on 09 September 2013
Do you have problems switching from Jaw chuck to Collet chuck or jaw chuck to Mandrel ? Here is a system that is easy to change and needs no radial adjustment.
Now there is a standard version for machines with spindle configurations A2-6 and A2-8. immediately available from stock. It makes the change to centroteX even easier. The 5-minute change-over from a size 315 jaw chuck to a size 100 Collet style chuck offered by the quick change-over system cannot be achieved by another system. It can also be accomplished without irritating adjustment and runout alignment as there is a built in zero position system.
Key advantages:
Dramatic reduction in clamping device change-over times thanks to a quick-acting closure mechanism [between 5 minutes with the crane and just a few seconds by hand]
No compromises in the ion of clamping devices, pick the right workholding every time
Change-over accuracy between machine adapter and clamping device adapter < 0.002 mm - without radial alignment is possible
No loss in rigidity, in comparison with clamping devices that are bolted directly on the machine
For easier handling, the Monteq mounting aid can be used for heavy clamping devices
