Deep hole drills even for the smallest diameters
Added to MTDCNC by MAPAL on 07 June 2017
Deep hole drills with very small diameters are needed for various sectors in the automotive industry, for example for the drilling of fuel injection nozzles, or for medical technology. In order to be able to produce these delicate parts, MAPAL has extended its portfolio of deep hole drills with internal cooling for machining centres to include models above one millimetre diameter.
The geometry of the new drills has been specially adapted to the small diameter range. Thanks to the newly designed chip flute and special face geometry, very high feeds and cutting speeds are possible with deep hole drills. Thanks to the innovative cooling channels, the drills are also suitable for use with minimum quantity lubrication (MQL). Despite lengths of up to 30xD, the gas/oil mixture is reliably transported to the cutting edges. Instead of a full coating, the new tools are coated only at the head for higher cost-effectiveness.
The new miniature deep hole drills are available in the diameter range from 1.0 to 2.9 mm (shank diameter 3 mm) for universal drilling in steel and cast iron machining and drilling depths between 20xD and 30xD.
