FB700II FB1320II and FB2000II Dust Extraction
Added to MTDCNC by MTDCNC on 01 June 2012
Now available from Air Cleaning Systems (acs) are its re-designed range of downdraught filter benches for dust extraction in the wood industry. The FB700II, FB1320II and FB2000II models that control airborne particulate are ideal for removing dust from sanding processes.
The new downdraught benches fully comply with the HSG258 legislation (controlling airborne contaminants at work) and incorporate an inverter control, filter gauges with 'filter full' indication, G4 pre/primary filtration and optional HEPA secondary filtration as standard. Additional features that are standard on the models are a motor fail warning light, 3-sided enclosure, levelling feet and an on/off push button control with 'power on' light.
The benches are complimented by two carbon filter benches designated FB700C and FB1500C to control odorous contaminants within an airstream, for example from a bonding processes. The benches will improve the immediate working environment and eliminate potential respiratory health problems for employees.
