Handy Set of Jaw Turning Discs
Added to MTDCNC by MTDCNC on 26 September 2012
Now available from SCHUNK, the competence leader for clamping technology and gripping systems is the new compact, light and attractively priced ADR sets of jaw turning discs. The new ADR discs make the precise turning operation of soft chuck jaws a simple and cost effective process.
In the past, operators had to use a variety of different rings. With the ADR discs from SCHUNK, only one set of turning discs is required, with the diameter of the discs being increased in 2mm increments via three bolts. These bolts are screwed onto the circumference of the discs prior to clamping in the jaws.
Since fitting holes are no longer required, the jaw turning discs can be easily used in a plug & work manner. In order to achieve a precisely adjusted intermediate diameter, the bolts can be milled to suit the requirement and replacements can be re-ordered as a spare part. The set of jaw turning discs from the innovative family-owned company is available in two sizes, for diameter ranges from 125 to 250mm and from 250 to 520mm. On request, the ADR discs can be supplied in a handy transport box.
