Infinite Workholding Solutions for Component Measurement from Thame
Added to MTDCNC by Thame Workholding on 28 July 2015
Workholding of components from the most simple geometry to the most complex imaginable part has now been simplified by Thame Workholding with its new Alufix modular fixturing system.
Developed for use on CMM's and measuring fixtures, checking gauges, assembly or welding fixtures, the new Alufix range is the ideal solution for manufacturers conducting design projects and producing R+D and prototype parts where product development changes are commonplace.
Manufactured from high-tensile aluminium, this modular system is available in six sizes that can be combined with each other to permit clamping operations on the most challenging of parts. The potential for the Alufix is almost infinite with base plates, bars, struts, blocks, clamps, screws, connectors and much more, all having the ability to interconnect to create the clamping structure that you require.
Once the customer has built and used the appropriate clamping device, it can be disassembled and the individual components can be used for new assemblies. The bars and base plates that form the construction of the desired clamping set are available in a vast array of sizes to suit the need of the end user. These bars and base plates are provided in grid dimensions of 16, 25, 40 and 50mm with centralised hole diameters of 8, 12.5, 20 and 25mm. This creates an exceptional level of flexibility whereby the customer can specify module grid sizes to support the clamping of the smallest of parts that require low clamping forces through to extremely large or heavy parts and structures that demand a robust solution.
The Alufix line guarantees precision clamping of all components regardless of material type, dimensions and geometries with a lightweight but stable solution that is not restricted by workpiece weight or size limits. Furthermore, the Alufix range enables the end user to combine various system sizes - and when its all disassembled, it requires minimal storage space. If customers are restricted on storage space, Thame can supply a range of workstation storage solutions for the Alufix. With the Alufix line being corrosion free, long lasting and maintenance free, these storage cabinets enable the customer to neatly store the individual Alufix elements for future re-use. For further details on how Thame can resolve your workpiece clamping dilemma, contact Thame on Tel: 01844 208050
