New Jaw module from Hainbuch with SPANNTOP or TOPlus chuck
Added to MTDCNC by HAINBUCH UK Ltd on 14 October 2013
This is the simple formula of the new modular clamping solution from Hainbuch. Using the new small jaw module from Hainbuch, about 80 % of usual components are covered, and for larger components it can be easily changed over to a large jaw module within 30 seconds. The basic unit is a SPANNTOP chuck or TOPlus chuck. So add to this the jaw modules, clamping heads and mandrels; you achieve reliability, accuracy, and safety that traditional jaw chucks lack especially for I.D. clamping. Clamp from inside with a jaw chuck – at any rate this is hardly done by anyone. Those who have experience with HAINBUCH mandrels are aware of the unbelievable, even seeming almost impossible clamping situations that are feasible. The new jaw module now completes a clamping system that offers the right solution for each clamping situation, without compromise.
Key advantages
  • Minimal interference contour, optimal utilization of the jaws
  • Flexible, fast and repeatable change-over to clamping head or mandrel clamping
  • Deadlength clamping with jaws [e.g. claw jaw clamping on the blank]
  • Rigid workpiece clamping with pull-back effect through the use of clamping head or mandrel [e.g. short clamping for machining finished parts]
  • Full passage with actuation of the clamping head
  • Ideal for sensitive clamping and delicate components
  • Can be used as a pick-up chuck on sub spindles
  • Also excellently suited for stationary use.
Find out more about this new system from Hainbuch by visiting their website here http://www.hainbuch.com
What are you looking for?
What is 2 + 8? (Spamcheck)
