New product developments and improvements make Seco's Disc Mill Cutter range even more attractive and appealing.
Added to MTDCNC by Seco Tools (UK) Ltd on 09 March 2017
Seco has announced that it has expanded its already broad and highly-popular range of disc milling inserts and cutter bodies.
In response to customer demands, the company has recently introduced its 335.14 small-diameter exchangeable head system, its 335.16 cutter range for T-slot operations, and cassette versions of its 335.25 cutters that incorporate round inserts.
Featuring small-diameter exchangeable carbide heads, 335.14 is inherently versatile with precise cutting profiles that can tackle any material. These cutters are ideal for groove milling, circlip grooves, full radius profiles and chamfering.
The introduction of reliable and easy-to-use exchangeable head systems help control machining costs and increase productivity.
The 335.14 product line is available in a wide variety of cylindrical and integrated collet chuck shanks with diameters ranging from 9.7mm to 34.7mm cutting widths from 0.7mm to 5.15mm.
Highly stable 335.16 cutters incorporate 4-edged inserts that deliver increased economy in T-slot operations.
335.16 cutters have state-of-the-art insert geometries that help reduce machining forces and noise and, as a consequence, significantly improve tool life. They also feature centralised cooling channels for effective chip removal ensuring superior surface finishes and high part quality.
The cutters are available in diameters ranging from 25mm to 50mm based on standard T-slot dimensions.
The wide selection of insert geometries and insert grades can cut many materials in widths ranging from 11mm to 21mm.
The expanded line of 335.25 disc mill cutters now includes new cassettes for 16mm and 20mm round insert diameters. These cutters deliver exceptional performance in numerous machining operations (i.e. full side, face or half side, face etc.), involving corner radii.
The exchangeable cassettes ensure long, reliable cutter performance and the wide choice of insert geometries and grades ensure more effective machining operations (and results) and improve cost-efficiencies irrespective of the material being machined.
Regular and extra-large cassette sizes accept 16mm and 20mm round insert diameters, and cutter diameters range from 100mm to 315mm.
