Pibomulti angle heads exclusively from Gewefa UK Ltd
Added to MTDCNC by Gewefa UK Limited on 08 October 2015
The latest in a range of innovative, high performance angle head tools from specialist Swiss manufacturer Pibomulti SA is a slim line head particularly suited to machining in inaccessible pockets or hard to reach areas such as encountered in aircraft wing structure machining operations.
So precise yet slim line is the angle head design that if required it can be positioned to drill a structure with just 1mm clearance between the edge of the hole circumference and a right angle edge of the profile while avoiding deflection and maintaining full machining power.
Pibomulti products are exclusively available in the UK through Gewefa UK Ltd of Corsham.
While the SLA angle head features a very slim machining head profile it maintains the features associated with Pibomulti special tools – high standards of manufacture, strength and reliability.
SLA ‘standard’ heads are available in five variants offering different power (0.5kW to 2kW) and torque (1Nm – 8Nm) options. Cutter sizes of between 3 and 12mm diameter can be accommodated.
However, bespoke designs to suit specific applications are a speciality of Pibomulti and they are happy to adapt heads to suit.
The Pibomulti range covers angle heads, speeders and multi spindle heads for Machining Centres, CNC lathes and standard machines along with turrets to improve the capability or capacity of an existing machine tool in the most cost effective manner.
For further information contact the sales team at Gewefa on 01225 811666, sales@gewefa.co.uk or visit the web site at www.gewefa.co.uk
