The powerhouse shoulders heavy loads
Added to MTDCNC by MTDCNC on 07 August 2014
The new Delta series of linear modules from SCHUNK are able to withstand very heavy loads and are ideal for demanding linear motions with high moment loads.
The new Delta 145C from SCHUNK is a particularly compact module that enables powerful strokes up to 4m. Its inner dual-profiled rail guide ensures maximum rigidity and precision. This promotes superior performance when absorbing heavy loads. To increase the reliability and the service life of the module, a specially fixed plastic cover strip protects the guides and drive elements from dirt.
The innovative family-owned company offers the module with the option of a spindle drive for constant high power and high precision or with an economically priced, large-sized toothed belt drive for extremely high acceleration and process speeds. The SCHUNK Delta series is finely graded and comprises a total of four sizes with profile widths between 110mm and 240mm with strokes up to 7,720mm (Delta 240C).
With a toothed belt drive, a maximum driving force of 2,200N, a maximum speed of 5ms-1 and a repeat accuracy of +/-0.08mm are achieved. With a spindle drive, the series enables driving forces up to 6,000N with speeds up to 2ms-1 and a repeat accuracy of +/-0.03mm. They can be flexibly integrated into systems by means of T-nuts or mounting strips.
