Thame Gets Machinists in A Spin With Rotary Tables
Added to MTDCNC by Thame Workholding on 04 February 2016
For manufacturers looking to increase the capability of their machine tools, Thame Workholding is offering its comprehensive range of Samchully CNC Rotary Tables. Designed primarily for Fanuc and Mitsubishi CNC control units, the Samchully chucks are affordable, precise and can be installed and commissioned with ease.
The huge range of rotary tables and trunnions to choose from offer a huge range of benefits that should make the Samchully range something worth taking a closer look at. From a benefit perspective, the new rotary tables are very lightweight and stable for manoeuvrability, the system sizes can be combined and there are no weight or size limits on workpieces. In addition, the fixtures are repeatable, the components are re-useable and the tables only require a small amount of space when they are not in use.
As with all products in the Thame Workholding range, the Samchully Series are high quality and long lasting.  The extensive line-up includes hydraulic NC rotary tables, tilting tables, multi-spindle tilting tables, direct drive rotary tables, and rear mounted tables, manual turn tables and much more. For further details, please check out the Thame Workholding website.
