XYZ Takes your machining mobile with the new 2-OP
Added to MTDCNC by XYZ Machine Tools on 25 August 2015
Always the industry innovator, XYZ has taken flexible machining to a new level with its new XYZ 2-OP machining centre. The new 2-OP is a machining centre so flexible, it can be easily loaded onto a pallet truck and moved around the machine shop.
The compact and remarkably versatile 3-axis machine incorporates a 6,000rpm BT30 spindle unit with an 8 station tool change facility and a zero point clamping system as standard.  The mobile machine tool has a working envelope of 355mm in the X axis, 305mm in the Y-axis and 455mm in the Z-axis - sufficient enough for all your small machining needs.
The new 2-OP has a ProtoTRAK control unit with conversational elements to simplify programming for the operator. Unlike other machine tools, the 2-OP has a creative tool change facility that pops out from the rear of the machine to eliminate any potential work envelope restrictions that are commonplace on alternate machines. Completely self-contained, swarf extraction is by means of a simple draw unit that can be removed from the rear of the machine in seconds whilst the coolant sump sits comfortably at the base of the machine.
This machine is completely mobile and sits upon four feet that easily allows an operator to get a pallet truck under the machine and move it around the workshop in a matter of minutes. Once you've finished with the machine, unplug it and move it to its next location. If you want one, get your enquiry to XYZ pronto, as the new 2-OP is selling fast...
