A VMC new, for less than 20K from Dugard
Added to MTDCNC by Dugard on 28 July 2014
The new Dugard 500A vertical machining centre has been developed to provide the marketplace with a flexible and compact solution that delivers rigidity beyond alternate machines in its class. With a heavyweight construction that gives the 500A a weight of 2500kg in a footprint of 1.6m by 1.8m, the compact 3-axis machining centre is ideal for any machine shop.
The 500A provides a high speed spindle with a speed up to 10000rpm that has a BT40 spindle taper to accommodate larger cutting tools for more robust applications. This ensures that the Dugard 500A delivers material removal rates that are remarkably high for a machine of its footprint. The 500A incorporates a 10 station automatic tool change carousel to reduce set-up times for the end user.
With table dimensions of 800 by 320mm, the machine has axis movement of 500mm in X-axis, 320mm in Y-axis and 400mm in the Z axis. These dimensions are rapidly covered by the spindle that has an 18000mm/min rapid feed rate. All this is now available from Dugard with a starting price from less than £20,000.
