Ajax machine tools extend their bed mill range
Added to MTDCNC by Ajax on 21 August 2014
Ajax CNC has extended its line of popular bed mills that provide the ideal bridge between the small turret mill and larger bed mills. Providing excellent capacity with value for money, the Ajax range is a great choice for most subcontract manufacturers and small machine shops.
These vertical bed mills are available in eight different variations to cater for a vast range of component dimensions and machine power requirements. The smallest machine in the range is the Ajax AJCBM-720 with an X, Y and Z axis travel of 720 by 380 by 500mm respectively. With a BT30 spindle taper and 5HP spindle motor, this relatively small machine is ideal for components up to its maximum load capacity of 400Kg.
The largest machine in the product line is the impressive AJCBM-3000 that offers an X, Y and Z axis movement of 3m by 800mm by 650mm respectively. This powerhouse can accept payloads up to 1600Kg with a distance from spindle taper to table of 170 to 820mm. Offering more power than the smaller machines in the line, the 10HP AJCBM-3000 has a BT40 spindle taper for higher stock removal rates. With another six machines in the range between the aforementioned smallest and largest machines, Ajax can cater for all 3-axis machining applications.
The key elements of the machine are produced from a cast construction to give stable rigidity and the slideways are hardened and ground and coated with Turcite-B to give excellent results.
As standard the machines in the bed mill line are provided with a Heidenhain TNC 320 or 620 control with conversational programming or the Siemens 828D with shopmill conversational control. All machines have AC Servo motors, automatic lubrication, halogen work light, slideway covers, good ergonomic design, table guards, inverter spindle drive system, power drawbar and a CE mark. As well as all this, Ajax can cater for more diverse needs with optional accessories that include fully enclosed guards, DNC software, tooling packages, clamping kits and machine vices.
These machines are carried ex stock...
LATEST PRODUCTS FROM Ajax
What are you looking for?
What is 2 + 2? (Spamcheck)
