Ajax Machine Tools showing 'BACK TO BASICS' machines at the MACH 2014
Added to MTDCNC by Ajax on 05 March 2014
The Machine tool suppliers at MACH 2014 will be showing a multitude of technology with spiralling cost of purchase starting at £100,000 to multi £millions.
Ajax have recognised that at least 50% of the potential buyers attending the show will be looking for simple to operate low cost CNC machines for small batch and one off production and are taking this into account with the machines they are taking to show customers.
Ajax’s European built AJEU Euroturn 200 flatbed CNC lathe with Siemens 808D full colour conversational control is the smallest in the three machine range having swing over bed of 402 mm, 502 mm and 650 mm and between centre distances of 750 - 3,000 mm.  Three speed gearboxes maximise torque from the 4 kW, 5.5 kW and 7.5 kW motors and quick-change tool post is included with option of an eight-station turret.
With machines starting at under £15,000 why would you not want to visit stand 5293 at MACH 2014 to see one in action ?
The Ajax AJCBM 720 bedmill is designed to bridge the gap between a vertical machining centre and toolroom milling machine with the added operational flexibility of a universal inclined head and Heidenhain TNC320 full three-axis contouring control.  The table size is 1,245 mm by 230 mm and able to accept loads up to 400 kg.  Longitudinal travel is 720 mm, cross travel 380 mm and 500 mm in the vertical axis.  The quill provides an independent traverse of 127 mm.
LATEST PRODUCTS FROM Ajax
What are you looking for?
What is 5 + 1? (Spamcheck)
