Ajax now offer the AJV 3 and 5 axis machining centres
Added to MTDCNC by Ajax on 08 June 2014
Now available from Ajax machines tools is a new series of 3 and 5 axis high speed machining centres. The New AJV 700 is an excellent mid-range machine that offers a large machining capacity in an extremely small footprint, making it the ideal choice for any machine shop.
With quality in every aspect of the new machine, the AJV700 is built upon a heavy duty construction that is combined with linear roller guide ways gives to provide remarkably high power machining with exemplary rigidity.
Capable of running at 48m/min rapids, this new machine moves around at very high speed for end users aiming to optimise productivity and reduce cycle times. With flexibility at its core the 3-axis AJX700 and the 5-axis AJX700 5X are both available with Heidenhain, Fanuc or Siemens controls to suit the exact needs of the end user.
 The main construction features include, direct drive to the spindle and axes, a 24 tool station with an extremely rapid 2 second change time and tool management system. With its heavy weight construction that comes in at a weight of 3,895Kgs, customers can be assured that the new machines will provide a robust and rigid machining solution for years to come.
Furthermore, this rigidity can enhance surface finishes and tool service life for end users that are conducting everything from finish machining through to heavy material removal.  In addition, Ajax is so confident in the build quality and robust nature of the new range, it is providing a 2 year warranty to provide customers with the peace of mind that they are buying into a concept of a high quality and affordable line of machining centre.
LATEST PRODUCTS FROM Ajax
