High specification a new Bridgeport Conquest 1000 VMC
Added to MTDCNC by ETG on 15 November 2014
An all-new Bridgeport-Hardinge vertical machining centre – the Conquest V1000 – is now available in the UK from the exclusive distributor the Engineering Technology Group.
Aside from its rigidity the machine features large, robust 45mm ball screws on all axes and 35mm linear guides are standard on the X-axis with 45 size guides on the Y and Z-axes. Axis travels are: X - 1020mm; Y - 610mm and Z - 610mm.
Options include part probe, tool probe, X, Y, Z-linear scales, coolant through spindle, a 4th and 5th (4+1) axis drive package, automatic power shut off, spare m-codes, chip conveyor and auto door to name a few.
Speed is another feature.  The V1000 provides very fast rapid traverse of 4.3m per minute on the X and Y axes and 3.6m per minute on the Z- axis with a powerful direct-drive 20hp, 10,000rpm spindle motor with a 30-tool swing-arm automatic tool changer.
As standard the V1000 is supplied with a Heidenhain TNC 620 control. The TNC 620 is a compact but versatile contouring control for up to five controlled axes and features a flexible operating concept with either workshop-oriented programmability using Heidenhain conversational programming or offline programming to suit.
'The Bridgeport Conquest V1000 Machining Centre offers a high degree of sophistication and functionality at an attractive price' states Martin Doyle, Director, Sales and Marketing for ETG. 'Like all Bridgeport machining centres, this machine reflects an outstanding commitment to quality and performance without compromise.
'It will be a highly versatile, high performance machine suited to a range of manufacturing environments.'
