Doosan wins international Red Dot Product Design Award for second year in a row.
Added to MTDCNC by Mills CNC Ltd on 08 April 2015
Doosan wins international ‘Red Dot’ Product Design Award for second year in a row with its latest 5-axis machine.
Doosan Machine Tools has won the prestigious 2015 ‘Red Dot’ Product Design Award with its high-speed, high-precision FM 200 5AX (5-axis) machine, which was launched in August 2014.
Doosan is no stranger to the ‘Red Dot’ winner’s podium having won the same award last year with its Puma SMX 3100 multi-tasking mill-turn machine.
Equipped with state-of-the art linear motor and direct drive technology, the FM 200 5AX 5-axis machining centre is ideal for high-accuracy simultaneous 5-axis contouring and is aimed at manufacturers machining a wide range of complex parts, including medical devices, automotive turbo chargers and other precision parts.
The machine has a rigid bridge-type base, composed of a thermally-stable mineral composite material with excellent vibration damping characteristics to deliver superior surface finishes and long tool life.
X, Y and Z axes on the FM200 5AX are driven by high-precision linear motors, providing industry-leading acceleration/deceleration feed rates with little or no backlash. The 4th and 5th axis table (200mm diameter) is equipped with direct drive motor technology that is both powerful and responsive, and can handle work-pieces up to 15kg in weight.
Travels on the FM 200 5AX machine are X-axis 200mm, Y-axis 340mm and Z-axis 300mm respectively, and rapid rates on all axes are 50m/min.
The FM 200 5AX has a 14 kW 45,000rpm spindle (HSK E40 taper) and a 24-position servo-driven ATC as standard.
Red Dot Design Awards are prestigious and are much sought after.
Comments Tony Dale, Technical Director at Mills CNC:
‘’To win the Red Dot Product Design Award for two consecutive years is a considerable achievement and reflects the scope and scale of Doosan’s research and development capabilities, and the company’s ongoing commitment to design advanced, market-leading machine tools.’’
