The Dugard 42mm bar multi axis machine for complex parts
Added to MTDCNC by Dugard on 24 June 2014
To deliver high production levels when turning medium to highly complex components, Dugard has now launched its new line of 42mm multi-axis CNC turning centres. With five new turning centres in the range, Dugard can deliver a solution for any turning application in the 42mm component diameter bracket.
The new Dugard 42iT, 42iTRobo, 42XT, 42TT and 42iTTU are supplied with a powerful Mitsubishi control unit and the option of a 60mm diameter capacity for larger parts. An innovative and outstanding automatic lathe, the Dugard 42iTTU is a 10 axis twin spindle unit with a B-axis to provide rigid milling and simultaneous machining. For customers with limited floor space, Dugard offers its 42TT 8-axis two spindle machine with a sub spindle that has X & Y axis positioning. Incorporating large linear guideways and high torque servo motors, the 42TT delivers the stability, accuracy and power for heavy duty cutting.
Also constructed of high quality components, the Dugard 42XT is a heavy duty machine that is extremely versatile and robust. With a flexible tooling set-up that provides 12 live tooling stations and 19 standard tool stations, the 42XT is ideal for the production of complex parts in one-hit. Completing the new line-up is the new 42iT and 42iT Robo. These 4-axis gang tooling lathes are an affordable alternative to turret type C-axis turning centres. With 6 turning tools, 4 boring tools and 6 live stations, the 42iT allows for rapid chip to chip times whilst the live tool spindles with both C and Y-axis can complete most complex parts in one-hit. Offering the set-up, the 42iTRobo is a modified version of the 42iT with an integrated Mitsubishi articulated robot for component loading and unloading.
Request a brochure on all models the 42 models click here
What are you looking for?
What is 1 + 4? (Spamcheck)
