Matec now from Dugard in the UK
Added to MTDCNC by Dugard on 28 September 2014
German quality that is custom built to the specifications of the customer is the new offering from Dugard, with its new line of machining centres from Stuttgart based Matec. The new range of Matec solutions will be the perfect complement to the already extensive Dugard product line up.
When opting for a Matec machine, the whole ethos is completely different to your usual machine selection/purchase. With the Matec line, customers don’t need to choose from a limited range of options, they can tell Dugard exactly what is needed and the expected performance levels, and Matec will deliver a machine tool to the exact needs of the customer.
Utilising cutting edge technologies and creativity, Matec prides itself upon providing a machine of the highest standard with the exact functionality levels you need. So, how does this work? Well, Matec works on a modular concept design that starts with a standard machine build. For example, the customer will work with Dugard to start the planning process and choose a basic machine from the Matec range.  Then the options are added; whether it is a CNC rotary and swivel tables, 5-axis milling heads, infinitely variable CNC milling heads, linear drives, handling systems or tool stations, the Matec engineers make it happen.
With thousands of satisfied customers worldwide, Dugard couldn’t be more excited about selling the Matec range of 3, 4 and 5 axis machining centres. Matec has a range of standard machining centres that include the Matec HV/HVU Series and the L Series. Brochures and videos can now be downloaded from the Dugard website.
