A mill with an extremely heavy duty build quality for a great price
Added to MTDCNC by RK Int Machine Tools on 26 February 2015
Every machine shop should have a manual milling machine, and the latest machine to enter the UK is the new Europa Milltech 2000 milling machine from RK International.
Despite being a manual milling machine, the Europa Milltech 2000 is offered with the option of a DRO system that enables the operator to position either two or three axes to an exact co-ordinate. The X and Y axes are standard on the Milltech 2000 whilst the Z axis can either be moved from the quill or from the knee, depending upon the model selected and the needs of the customer.
The new machine is also available with a 'Millstar' DRO unit, which acts as a co-ordinate measuring system for the Z-axis. Located on the machine column, this can significantly improve the precision for the end user, particularly when drilling and tapping holes. The machine has an extremely heavy duty build quality with a cast base that supports the spacious 1244 by 230mm table size.
The spindle speed can be easily adjusted via a hand-wheel on the column. In fact, the machine is so user friendly that the MTD team reviewed the Europa Milltech 2000 at the Leigh UTC training academy in Dartford where an apprentice gave us the lowdown on how user friendly and easy the new milling machine is to operate.
LATEST PRODUCTS FROM RK Int Machine Tools
